I've got some 8ah Headway cells that are at about 0.9v, some at 1.1v and some at 2.5-3.0v.
I have an adjustable benchtop power supply (30v, 10A).
I also have some busbars that I can connect up to 12p.
What is the best and quickest way to charge these and would there be a different method for charging the lower voltage cells vs. the higher voltage ones?
I was thinking for the lowest voltage ones to just put them in 12p, set power supply to 3.6v and crank up amps as high as they will go.
Or would it be better to connect in series like 4-8s and set voltage equal to 14.4v - 28.8v? Then after the series charge connect them in parallel to top balance and charge to 3.6v
I've never used a PS to charge before, so I also need some help with the correct order of things. I think I set the voltage first with nothing hooked up and then connect, yes?
Thanks
Thanks
