ericfx1984
- Oct 10, 2021
- 741
Hasn't been a lot of sun lately... So I've been unfortunately having to use generator more than I care to
In an effort to increase my efficiency I looked around to see what I had
I had some switching power supplies... They were 12 volt and adjustable so I put a pair of them together in series and adjusted them to about 26 volts
These are 30 amps so it would have been about 30 amps at 26 volts... Or about 780 Watts
I piped these into the solar panel connection on the MppT charge controller... Now this is a 60 amp unit
Additionally I have a 100 amp charger that is built into my inverter
I guess I should also mention that the entire setup is 4S
When I first started running it everything seemed to be working just fine I had about 55 amps hitting the battery at about 13.8 volts
After a little while this all changed... Basically as I was monitoring it on the app you would see the MPPT charge controller ramp up to about 55 amps of charge rate and then a few seconds later dropped down to about two or three amps Then a couple minutes later it would try to charge again ramping up to 55 amps and then drop back down to a couple amps
I decided to go down and see if anything was showing up on the display... I noticed that the red warning light would flash on the charge controller right before it would drop to a lower charge rate
And of course the next day when we had plenty of sun the charger seemed to work just fine
I even tried this on a couple other MPPT charge controllers that I had with similar results
