ericfx1984
- Oct 10, 2021
- 741
It's been several days without sunlight...
So I have been trying to come up with a faster way to charge batteries when I'm using generator
Currently I have a large 4s battery bank. About 20 kWh
My Aims power inverter has a built in charger... About 85 amps
I was thinking maybe I could either pipe this 30 amp power supply directly into the battery bank, or I could disconnect the solar panels on one of my charge controllers and hook the power supply up to the solar panel input...
I should also mention that I have four of these power supplies
The power supplies are adjustable and can be set to 14.6 volts or whatever no problem
And I'm about 98% certain that the power supplies can be connected in series to increase the voltage
