Interesting well thank you for the response. Would upping the voltage of the system to say a 24v inverter make it more possible you think?The washer is no problem.
An typical electric clothes dryer requires split phase 120/240VAC 3000 watts and up.
Its pretty hard to find a split phase inverter at 12 volts.
Possible as in almost anything is possible but far from practical IMO.
Yes.Interesting well thank you for the response. Would upping the voltage of the system to say a 24v inverter make it more possible you think?
So a gas dryer would be okay to run on a 12v system with a inverter that met the required watts it needed for the load?Gas dryer, yes.
Yes it is. So 48v system with the proper inverter should allow to operate smoothlyYes.
I'm going to guess this is a residential clean slate install.
If it I suggest you consider 48 volts.
It would operate but 3kwh per hour to dry clothes is going to get expensive.Yes it is. So 48v system with the proper inverter should allow to operate smoothly
lol very well thanks for the input everyone!Luckily there is a direct solar clothes dryer.
Thank you this has been very helpful48v much easier.
I run a number of household circuits off a 48v inverter including refrigerator, washing machine, sump pump, garage door opener and a couple other things.
You need an energy audit and then you can size the battery, inverter and solar panels to match. It won’t be cheap so at some point you will have to prioritize.
It's the self cleaning cycle that gets you if you don't collect when buzzer goes off. You get stuck in an infinite loop.Luckily there is a direct solar clothes dryer.
We have a LG washer/dryer combo normal sized that runs on normal 120 ac plug... It uses little electricity but takes a long time to dry... It is also ventless so no holes in the wall needed...The do make 120 volt RV washer & dryer laundry pairs which require 10 amps, 1200 watts and they could be run with a 2 kw inverter from an adequately sized battery pack
