carterjohnsons25
- Mar 26, 2021
- 41
- I have six 48v Packs (200lb each) that will be used in parallel for one Very large (1200lb) 48v battery ~85kWh
- Each Pack will have its own Smart BMS, Bluetooth enabled
- Need to see all batteries at the same time. Not disconnect and re-connect between packs
- Any BMS recommendations?
- Will each 48v pack needs it own display specific to each BMSs Bluetooth?
- Is there a BMS / App combo that will read the Bluetooth from all 6 48v batteries and display on a single screen.
- Other suggestions to get full readouts from 6 48v packs that I am missing?
Thanks in advance.
