Bluedog225
Texas
- Nov 18, 2019
- 3,010
Good morning,
I was thinking about taking one of my LiFePo 12v 100 ah batteries on the small sailboat (or kayak) for some multi-day camping. It occurred to me that I ought to check on what happens in the event of a capsize. If completely submerged in salt water, I’m guessing that the battery shorts and melts. And if splashed it would burn off the water causing the short so damage might be limited.
Does this sound right?
However, the primary purpose of this question is what happens to someone in the water with a submerged battery? Say 1-2 feet away. Are you ok because you are not in between the terminals? Or are you SOL in the general neighborhood?
Thanks
Thanks
