OHIO_Tom New Member Joined Feb 13, 2020 Messages 26 Feb 13, 2020 #1 Could you use a Anl fuse as a buss bar to connect 4 - 3.2 vdc lithium ion batteries in series , or is this not a good idea?
C cass3825 Solar Enthusiast Joined Jan 11, 2020 Messages 337 Feb 13, 2020 #2 Interesting idea. Technically it should work just fine. EDIT: MrNatural makes an excellent point below! Last edited: Feb 13, 2020
MrNatural22 ?SW sunshine =⚡️⚡️lit up thru the darkness✌️ Joined Sep 20, 2019 Messages 1,647 Location 1000 miles to somewhere Feb 13, 2020 #3 Just wondering what may occur if one somehow pops? ?
OHIO_Tom New Member Joined Feb 13, 2020 Messages 26 Feb 13, 2020 #4 MrNatural22 said: Just wondering what may occur if one somehow pops? ? Click to expand... Very good question. Maybe I should just use them between each battery pack , I'm planning to connect 6 banks together for 600ah of 12 vdc. Thanks for your reply ?
C cass3825 Solar Enthusiast Joined Jan 11, 2020 Messages 337 Feb 13, 2020 #5 MrNatural22 said: Just wondering what may occur if one somehow pops? ? Click to expand... If the pack has a BMS, a mid-pack open circuit will most likely damage/destroy the BMS.
OHIO_Tom New Member Joined Feb 13, 2020 Messages 26 Feb 13, 2020 #6 cass3825 said: If the pack has a BMS, a mid-pack open circuit will most likely damage/destroy the BMS. Click to expand... Great food for thought ?
