Inverter
Welshman
If my inverter already comes with a replacable fuse. Do i need to add an inline fuse also???
Thanks
Thanks
Code:
positive
|<->fuse<->battery<->shunt<->|
|->fuse->inverter----------->|
|<-fuse<-charger<------------|
                      negative
The systems we make are like ladders.
The busbars are like the risers.
The circuits are like the rungs.
The battery should have over-current protection as close as possible to the battery positive terminal.
All the other circuits(branch circuits) should have over-current protection as close as possible to the positive busbar.
The branch circuit over-current protection is intended to isolate a fault to that particular branch circuit.
The battery fuses is the last line of defense to prevent catastrophic failure.
This is an example of a fused busbar which makes it easy to follow best practice.
Notice one of the positions is un-fused.
That is the where the battery is attached and the battery is fused as close as possible to the batterty positive terminal.
Thanks
Hi Taffy,
The fuse for the inverter is to protect the inverter. You also need to fuse the wiring from the battery to the inverter. To protect the wiring from meting and causing a fire.
For a start what voltage system do you have, what size wattage of the inverter and what is the wattage of the largest appliance that you will be using.
Fellow Taffy here from Newport, Gwent but now live in Australia.
Hi Taffy,
Hi ausie welshman lol (tim tim)
Its. 12v system, 135ah battery and 500w inverter……im only going to be charging tool batteries, nothing to more than 28w charger
30a fuses come with the inverter……..1 inside and i spare
