I have 12 x Enersys Supersafe 12V 170ah batteries 12T170FS manufactured in 2018. They are a standby/backup battery. How do these fair in a battery bank for solar? My intention is to double up on these to reduce the DOD. Have these batteries been successful in an off grid system?
I found one quick reference for these:
Enersys will also have other more detailed documentation on them if you dig a bit more.
They are high quality batteries but as with any battery it comes down to what state it is in when you get it and what you hope to do with it.
My home backup system uses very similar batteries. Mine are the Enersys Supersafe SBS 190F. You can read about my system here:
Greetings from down under. I live in a home near the small town of Bellingen, in northern NSW, Australia. Glorious country: That's our home at left centre, and obscured by the tree and slightly off the left of the image is a secondary dwelling where my Mum lives. 12 acres, behind our home (to...
diysolarforum.com
The have units actually useable for hybrid battery applications:
Have a ferret around the Enersys site to see what data you can find on your model.
I load tested mine and they were good, and I'd say the data centre which sold them barely used them and just had a policy of changing them out after a certain amount of time. But without any data on how they have been used and treated it's always a bit of a lottery. Hence why they can be pretty cheap to pick up.
I have eight batteries in two banks of four for a 48 V system. While they are 190 Ah units, that's their nominal 10 hour rating. The 20 hour rating for mine are 212 Ah, so a nominally 20 kWh bank.
Now I don't cycle mine much, regular cycling is using less than 5% of capacity a day and they are charged every day with solar PV. Their primary task is for home backup when the grid supply goes down. But they also act as ballast for the loads I do have running from the off-grid PV system (pool pump and office peripherals). IOW mine are pretty much kept in that 95-100% state of charge range, with occasional dips down to ~80% for a typical grid outage backup scenario.
I work on the basis that I can comfortably draw 8-10 kWh out of the bank if needed, which provides us with 16+ hours of outage coverage. In general by then solar PV would be able to start recharging the batteries, or if PV output was not sufficient then I can just fire up the generator.
I will be expanding the functionality of my system to handle household loads on a more regular basis however the storage capacity for that job will be LiFePO4 batteries - they are far more suited to regular deep cycling. I'm hoping to cover about 5-7 kWh/day with those.
