Eg4 float voltage question
Mannfamilywoodworks
Ny
Hello. This may be a silly question but I noticed float voltage is set at 54.0v by default with my growatt 6k AIO inverter.
It is setable.
I’m wondering if I should change this setting?
Eg4 batteries spec sheet states 56.5v.
I would raise it to at least 55v. So that the BMS can top balance better.
56,5v is also fine. And recommended by the battery manufacturer. I was just giving a more conservative option. The difference between the two will be a very small amount of energy.
Awesome Thankyou for a quick confirmation.
I’m going to change it to 55v now.
#12 should be set for how much reserve you want to always have.
#13 should be set for when the solar can cover your loads and also charge your battery. Without switching back and forth a lot.
I have mine set at 20% and 40%.
