Note that the IP22 doesn't come with the battery cables, as it would depend on how you plan to install it.
If you're not making your own cables, I ordered some from BatteryCablesUSA.com which was recommended by other forum users.
Since I planned to use the IP22 across several batteries, I purchased 6 ga AWG cables with SB50 Anderson connectors (to IP22) + SB50 to M8 cables (to each battery).
