Truck off grid
Bob!
Yes did this correctly but its flashing and beeping so its wired incorrectlyI looked up Renogy meter on Amazon & found the 5th item picture is a wiring diagram.
Linky https://www.amazon.com/dp/B07RP5B5P7/ref=cm_sw_r_taa_dVIHEb61AD0FH
- B- is battery to the bolt
- P- is bolt to all loads
- B+ is battery positive to the blue connector in the middle.
- The Molex harness should be configured correctly & connect the meter to the shunt.
