My inputs would be the grid and PV, my output would be AC to loads. I'd have a solar array and EG4 batteries.
When the grid goes down does the AIO keep putting out power as long as the batteries are above the minimum?
When the grid goes down and comes back up is there any kind of a manual reset required?
When the grid goes down and solar is below the battery minimums: When either solar catches back up or the grid comes up is there any kind of a manual reset required?
Thank you!
Thank you!
