lowerpower
I want to run an EG4 6000xp to power a tiny home. I'll have at least 2K solar, 5-10kwh of batteries, and up to 10amp split phase grid (10 amp per leg)
Is it possible to set the EG4 to charge on grid but limit to 10A? I'd like to priority Solar, then grid to charge, but run the tiny home off the inverter only as I need the 20A legs in the tiny home.
FYI 10A comes from the location has #10 feeding from the main house panel, but it is a long distance and it is calculated for max 10A without critical voltage loss. I want to use the Inverter+solar+batteries+max10A grid
Is this possible with the EG46000xp? Was not obvious for me reading the documentation.
Is there a better way to go than the EG46000xp?
Thanks,
Mike
Thanks,
Mike
