EG4_Jared
Online Support for EG4 Electronics
I would like to install the EG4 Hybrid Mini Split 12k (considering 24K) and see that solar can be directly connected to the unit.
My question: Is it at all possible to use existing solar running to EG4 6000XP inverter to power the mini split? In essence, shared solar for both the EG4 6000XP and the EG4 Hybrid Mini Split. If so, how would something like that be wired up? In other words, does the hybrid mini split need it's own dedicated solar panels? The setup is completely off-grid and will never be tied to the grid.
I would recommend a dedicated array if you were wanting to power the mini-split off of DC. Otherwise, you can connect the mini-split to the loads panel and power it off of AC with the 6000XP.
