I am running some tests and trying to estimate the viability of direct PV HW heating. Planning to use a solar HW MPPT controller, but testing a simple direct connection for now.
Current setup is a 55Gal dual element HWH with direct DC from the PV array connected only to the 5500/240v lower element, measuring 10.3 Ohms.
The system is based on Suntech 200W, 26 Vmp, 7.6 Imp panels. I could use either 8 (4S2P) or 9 (3S3P) panels. In all cases, they will be moderately shaded and mounted on a south facing wall. I am at 42 latitude with 4.6 solar hours.
Actual test of 3S2P, 6 panels, temporary mounted in the proposed location give a metered peak output of around 4 Amps and 45 Volts. Most of the day the output ranges from 1 to 2.5 Amps.
I expect more power once all 9 panels are mounted & positioned higher up on the wall (1 to 5 degree tilt might be possible), but I don't expect a dramatic increase - probably peaking around 5.5 amps and 65 Volts.
I can vary the HW heating element, but not much else in the setup and can not reduce shading from tall tree trunks all around.
I don't have enough experience to determine whether, based on the results so far, this is a potentially viable setup, even once an MPPT HW controller is in the mix. What do you guys think?
