countryviewacres
I started installing the EP Cube from Canadian Solar yesterday. I am installing a 4 battery setup (13.3 kw hours) So the installation has been very simple. No battery cables to mess with. Brackets secure it to the wall. And they space everything off the wall a few inches. So the mounting surface doesn't need to fireproof.
You can see from the pictures the rapid shutdown is already pre-wired into the system. It has 4 mppt inputs (I am using 2 inputs so far with 7.36 kw of solar) And the gateway can pass a full 200 amp service, but I am only sending 100 amps in and out, with 100 amp critical load panel.
Here what it looks like so far. Hoping to get the conduits done and wired up tonight.
Since it is a new system, I thought you guys might want to see how it looks.
Evan - Country View Acres
