Bchristian227
- May 9, 2020
- 2
Has anyone attempted to put a bigger bolt in the renogy 100ah lithium battery? The bolt seems fine, I even switched it to another battery and it tightened down just fine. I can only hand tighten it because the inner threads are stripped. My battery monitor is reading 10 amps going out with nothing running, and I think it is because of this loose connection. Not alot online on using an oversized bolt. Anyone have this happen and if so, what did you do?
