After the G99 fast track application you should receive a confirmation that they have accepted the application so you can then install & what export they would allow. In my case the DNO said I fell under SGI-3 which is up to 32A export.Is that your G99 application. I have one in at the moment since begining of July and heard nothing. Wondering if I should go ahead and install and send in the commissioning sheets A3-2 and G100.
