gucu
- Jun 7, 2020
- 15
Hi All
I am a youth worker based in Cornwall, UK and over the last few years I have been teaching myself several new hobbies as I head towards 60 and possible retirement! Although not probable!
A few years ago we were able to buy our first house which was amazing and I turned to learning woodwork, permaculture/food forest gardening, electric bikes and off-grid living. We had already lived two years in a 35ft library van using off-grid water and a compost toilet but we had an electric hook-up. So, on arriving in our house I built a shed at the bottom of our garden and have been using a small off-grid system to charge hand-held batteries and my bicycle battery. The system consists of:
4 x TPS-102 12v panels with rated power 12w @ 17.5v 4.8ah capacity
2 x Alphaline xv24 MF batteries running 2 x 12v
1 x Steca solsum 10.10f 10a 12/24v solar charge controller
1 x Sterling Power 12v Pure sine wave Pro Power SB 300 watt inverter
The system works and in the summer works well. Charging a battery usually takes the system from green to orange. I also have a Honda EU10i generator in case I need to top the batteries up. But as you can tell this system doesn't perform so well in the winter. It also restricts me as I have a 1400w mitre saw which I take back the house to run. I am thinking of buying a bench drill press which will run 350w. I need to upgrade my system. As I am still learning I am hoping for some hand holding!
Can I run this system in tandem with another system please?
Can I upgrade this system by adding panels, a more powerful inverter, etc please?
Or am I better off scrapping and starting again?
I don't have a lot of money and so I am hoping that I can upgrade elements to be able to keep this system running until a new system in place. A for instance, as I want to run the 1400watt mitre saw, is it a good idea to purchase an inverter for the system first? But if I do, should I upgrade the batteries as well?
Many thanks for all the replies.
Rich
Rich
