omsmall
- Dec 31, 2019
- 11
Good day friends,please I need your help, anyone encounter this kind of issues and how to fix..... I noticed that the hybrid inverter I used in installing systems for clients always do this particular issue which I think needs to be set.
The issue is like this.
Let me use for example:
Assuming I have 6panels of 250w each, all connected in series, and normally input pv voltage is supposed to be 170v, but each when there is new day, once the inverter starts charging, it's input pv voltage would be very very low, also input pv current even why the sun is hot, sometimes the pv could be 60v and current 2A, under heavy sun, but immediately you switch off the inverter and power on again......... The input pv will become normal generating the voltage like 170v 8A (according to the weather), this similar issues happens to all the hybrid inverters I used for customers because they are from one manufacturer...... Please I would like to know if anyone have help for me, so that everyday when the pv recovers, the pv input wil be normal, not when they would switch off and on before it's becomes normal.
