Beware of Anenji because of absolutely no support in case of problems! You can scrap any faulty Anenji equipment! My experience:
I installed an Anenji MPPT 3.6KW Off-Grid Solar-Wechselrichter 100A Hybrid 230Vac 24V 500V in June 2023 with 2 kW Solar panels and 1,5 kWh battery to charge a hybrid EV in my garage. However whatever the settings the inverter turned off after less than 70min on unknown grounds; solar or battery power was still available. After about 2 months the inverter completely failed, no display, no output anymore. Anenji immediately shifted the communication from ebay messages to WhatsApp, firstly promised to help, asked questions, gave suggestions and finally diagnosed failure of control board as rootcause. Eventually they refused to supply a new control board but in the end stopped any communication at all!
I can confirm that the hardware looks pretty good but the software/firmware appears to have problems (glitches that turn off the inverter?) and above all, there is no support at all. I have made the same experience as ebay user 1***k (818):
„Buyer beware, don't expect any warranty or return if faulty. My unit faulty, returned at my expense, seller refused to accept delivery. Had to get refund from PayPal. Shame could have been a good item. Good comms via WhatsApp but lied at end.“
Ebay is of no help, they don’t care that Anenji refuses to give any sort of support or garantee. No chance to change the judgement of the seller in ebay!
