kolek
Inventor of the Electron
- Sep 29, 2021
- 654
Deye 8k, previously it would activate AC momentarily and then throw F08 GDFI_relay_failure error. To solve F08 error I've wired load N to ground as recommended here, and now the unit won't do anything but show DC power from the panels. Inverter now makes no attempt to start AC power. Deye support has been absolutely useless, I've exchanged messages with them on multiple occasions. If you purchase a Deye inverter, you are on your own.
No battery and no grid hookup on this yet, just a string of 7 x 455 watt panels. The panels are in full sunlight.
Previously the unit was at least starting the AC conversion, now it's not. Could a fuse have been blown? No new errors showing. No Alert light. Only green LED is DC power.
