Not good initial results, but could also be a connection result. If this cell exceeds 3.65V while the others are still trailing, AND it's not a BMS connection issue, looks like a bad cell.
The SoH of 63% is a very bad sign. This cell may only have ~60% rated capacity...
That's a glaring failure that should generate a warranty replacement without question.
