Jmhai3
I was trying to get the WiFi to work and the unit was on and connected to the one 48v lifepower4 battery and it had no load or anything plugged in on AC in or out and PV not connected. It just shut completely down and smelled a little heat from it. I shut it off and the battery reset everything and now will get a flashing 6P code when inverter is turned on but nothing when the inverter switch is off like last pic. The first two are how it is flashing. If I connect the AC in it show volts in but does the blinking screen with the 6P flashing.
