Rapidrob
I've done a search here and not found what I need to know.
I'm going to use 8 ( eight each ) 38120S LiFePo4 batteries to build a portable battery pack for my HAM radio which I will be running at 100 watts ( 22 amp draw on transmit )
I can either use 2 ( two ) packs of four batteries each having a BCM and somehow tie the two together?
or one pack of eight wired to produce 14-16 VDC ( radio wants to see 13.8 VDC on transmit ) if that is possible?
I've not seen a BMS for running two battery packs together for one constant output of 12-16 volts. nor one for eight cells providing 12.8-16 VDC?
Some of the 18650 battery packs can have a BMS that jumps from one-to-another. Is there a BMS for 38120S batteries that will do that as well?
I would like to get fours hours of run time on the radio. Transmit every 30 seconds at 22 amps, and receive at 1.5 amps for 30 seconds.
I do not want to run QRP ( low power ) out of the radio.
I would appreciate any helpful info from you experts. I will in the future run a Solar cell charge device to help maintain battery current.
Thank you.
Thank you.
