2 Big Battery LiFePO4 Packs for Sale
garetjax
I have two of these wheeled packs for sale - sadly need to move for work so can't setup my solar project. I have never used them or tested them.
I also have a brand new Growwatt 3000w 48V with wifi module that I was going to use with it and "Renogy 4Pcs 270 Watt 24 Volt Solar Panel 1080W for Off-Grid On-Grid Large Solar System, Residential Commercial House Cabin Sheds Rooftop, Multi-Panel Solar Arrays" still in the pallet I received from Amazon.
I'm in Mooresville, NC. Looking for Best Offer for any of them - I prefer not to have to move them.
Thanks
Im close to asheville. What size packs. I'm setting up a 24v system. Would like around 400ah or more. Can i get some pics.
I moved to Richmond VA. They are these https://bigbattery.com/product/24v-lifepo4-power-wall/
Electrical Specifications
Nominal Voltage: 24V
Nominal Capacity: 3kWh
Max Charge Voltage: 30V (each cell voltage should be less than 3.75V)
End of Discharge Voltage: 20V (each cell voltage should be more than 2V)
Maximum Continuous Charge Current: 130A @ 25℃
Maximum Continuous Discharge Current: 130A @ 25℃
Configuration: 8S
Chemistry: LiFePO4
BMS: 130A
Anderson Quick Connect: SB175
Breaker: 125A
Price for both? When did you purchase batteries? I was about to place order for raw cells from China but if you have those for good price i may buy them. How much if i bought the inverter also? Could you meet me halfway?
Im very interested in the batteries. Not so much the inverter since i will probably stay with 24v for now and need inverter charger.
Hi - sorry someone local just bought the lot - batteries, panels, and inverter.
Thanks
