drbytes
- Oct 21, 2021
- 113
Hello
So I've got a bit o an issue; my smartshunt reads over 200+ volts when there is a usb-to-serial connected. When it isn't connected the readings are fine.
This setup has worked for well over a year but then from one day to another it no longer read the right values.
It's hooked up to a pi that does the whole solar thing. I already tried interrupting the positive and groun wire from the usbtoserial to the smartshunt but the problem persists. The second I disconnect it it's back to normal.
Is it borked ?
Is it borked ?
