Wolffy
- Nov 27, 2019
- 8
I've seen cones for the end of the pontoons, but they would need a good tig welder to properly install so I probably won't bother.
That triangular support is part of the motor mount. Mine was also made for 115hp and is way overkill for an electric...so my thought was to just shorten in by a few inches so it doesn't even touch the water. I think the flat back toons are the bigger drag though.
MinnKota props are very inefficient. They are designed for several sized motors for use on several sized boats...from 1000lb pontoons like mine to 20,000lb trawlers. And being weedless hurts their speed and efficiency too. I know I'd gain a couple MPH with a properly tuned prop. Right now my motor has a max draw near 30 amps, but MK rates the motor at up to 46 amps. So that motor is just loafing along spinning an undersized prop. Problem is, nobody makes a good prop for them.
I've read about a few people gaining a few MPH by using a model airplane prop, so I tried it. I had a bunch of RC props laying around, so I started with an 11x7 composite prop. Took 5 minutes to bore out the center hole and add a slot for the shear pin. I jumped on the boat hand headed up my canal with the stock prop and recorded top speed. Then I quickly pulled up the motor and swapped props, took less than a minute. I swung the motor back down and turned it on and.......I went backwards, doh! I need a pusher prop, not a puller. So those tests are on hold for now.
That motor you linked to looks like a beefed up brushed golf cart motor. I had thought about just picking up a used golf cart (they are under $500 with old batteries here) and using the motor and speed controller from it. Ideally I'd like a brushless motor though.
https://www.goldenmotor.com/ sells brushless motor kits, and they also sell large electric outboards. Someone here bought one a while back...maybe if he's reading this he can chime in and tell us how it's working out.
Solar Pontoon Boat Controller Parameters
Hi. I'm new but very interested in figuring this out. I have watched William Prowse's videos and I got inspired to make my own solar pontoon boat. I have a big flat roof on the boat that is perfect for solar panels so I put 8 of them up there. I have it all wired now but I have questions on...diysolarforum.com
Have you thought about 2 trolling motors one on the back of each pontoon. I have been thinking about making an electric pontoon also and that's what I was planning on doing my boat is going to be a 16 foot as our lake is a small 600 acre lake in northern MN. I was going to put the panels on the top of the folding bimini. batteries under the seats.
sounds like a fun project keep us up to date on it.
Ron
