I have my 24 volt battery built. I need to order an inverter. I had finally decided on the
Growatt 3kW Stackable Off-Grid Inverter | SPF 3000TL LVM-24P.
But I just watched a Signature solar video on YouTube that recommended using a separate charger for charging the batteries when using this inverter.
One of Will's videos shows just adding an extension cord to a MPP AiO for charging a small off grid system but the MPP is only 2KW.
On the Growatt if I set the LCD setting 3 to “APL 03” can I get away with just using a cord to charge?
Does anyone have a suggestion for an AiO with a 24 Volt input and 2.5-3.0 Kw/120volt output? Under $800 .. Thanks K
