GSteinenduro
Hey crew, first time posting so I appreciate any help up front.
I'm going to be building a small 3-4kw ground mounted solar array for a tiny house I own. It's going to ideally be set up in a way that everything is self contained away from the home, for space constraint and safety reasons. I'm going to build out an insulated box to house the inverter, batteries, and charge controller. Ideally I don't want to mess with having to tie directly into the breaker box, but instead I'd like to run a 30amp RV power chord from my system into my existing plug in on the tiny. I'm struggling to find a solution though. It seems you can run a 15amp adapter off the inverter, but I'm not confident that will work if we're running multiple loads at at time. What options do I have to run such a power chord from the array to the home? Thanks!
