320ah LifeP04 in a 100ah Case Size? With Heat and Bluetooth.
Rocksnsalt
SoCal
Royer Batteries 320Ah Smart Heated LiFePO4 Battery in the size of a ”normal” 100ah?
Seems to good to be true, same as I think about the Monster Lithium 344ah offering.
Is this actually possible? And if it is, why isn’t the marketplace full of such?
That much power in so little space would be a huge plus for vans, rv’s, tiny homes etc.
It kind of is, at least in applications which require dense batteries. The lithionics 320AH is similar in size to this and it's everywhere, despite costing $4500 each.
The lithionics is 3.15 watt per cubic inch and 68 lbs, this battery is 3.5 watt per cubic inch and 64 lbs.
The cells they claim to be using are over 5 watt per cubic inch so the battery is theoretically possible. But I don't think most applications really need the densest possible energy storage.
Thanks for your response.
Space is key in vans / small RV’s, so a lot of energy in a small form factor is very desirable.
But at $4500 /320ah, Lithionics batteries are for the 1%’ers, a group I and most other van and small rv owners are not part of.
So I guess my “everywhere” is not the same as yours. ?
So I own a "B+" type RV, in which they are fairly popular because space is tight and you're often retrofitting them in. And the Ekko comes with the lithionics, plus a couple of others. So that's why I said they're everywhere, in that narrow space. And up til now I haven't found any equivalent to the Lithionics in energy density (aside from building your own).
But in any bigger RV space doesn't seem a huge concern, people even just go for 4+ battleborns which are very space inefficient. And I also follow a lot of van outfitters and they seem fine with including a big electric box either under the bed or over a wheel well, where again they're fine with using a bank of battle born or equivalents. So that's why I sort of contradicted myself and said there doesn't seem to be much demand.
Anyway, I stumbled across this post because I just heard about this battery and was looking for information on it. Didn't find much. I do not have the lithionics battery myself, too expensive.
Re the Royer batteries, I have a bit of a problem with companies that don’t post the price of their product(s).
The cost per watt hour is not competitive so they are not very popular for most people.
Here is one:
Another compact 300AH is the Victron:
If you have the money, you can't beat these:
UL listed for crash tests, its the top tier battery for the 1%
Yes Lithionics and Victron are top tier.
The small size but high power of the subject batteries are what I find interesting, or questionable. If they are for real, good quality and dependability at a reasonable / competitive cost, then I like the trend. But I understand, some companies are not trying to be competitive, but make what they view as the best product.
Here is one:
Nice, but notice
  • Charge Operating Temperature:
    • 41°F to 122°F
    • 5°C to 50°C
Nice, but notice
    • 41°F to 122°F
    • 5°C to 50°C
That battery has a built in heaters, if the temps go to low it turns the heaters on to warm up the battery and then they will charge. Many of the Chinese batteries have the same thing, a switch over to heat it up and then allow charging.
But you can get the SFK battery with a heat switch and just turn it on and it will keep the battery around 70 degrees.
I have there kit version without heaters but I'm in Central Texas does not get very hot here so for me I did not need the heating. My kit is a 280AH version and so far it has worked flawlessly.
Here is one:
That SFK battery is interesting. I absolutely love that external temp control option. It appears continuous discharge rate is around 100a, does that seem a bit low to anyone else?
Are you trying to charge the batteries near freezing? 41 is pretty cold.
Yes of course, why wouldn’t I?
The sun is out plenty of times when it’s 41F or lower. And 41 is a bit of a chill, but it’s well above most LifeP04 bms charge parameters of 32F. And hardly what many on this forum would call pretty cold.
If the sun is out or I’m going for a drive and the battery has “room” for charging of course I’d like some free energy, either from the alternator or solar. Especially for the 1%’er price point of Victron or Lithionics batteries.
But as was pointed out by @Sam Cho TX that particular battery has heaters.
Just seems like a lot of energy being used to warm, at a higher temp setting than is normally seen.
34 or 35F I understand as a safeguard, 41F is way beyond conservative.
Just my opinion, and I’m not claiming to be an expert by any stretch.
Don't go around Charing batteries when its this cold, you'll do more ham then good. Most electric cars don't start charging properly until they are sufficiently warm:
So yeah I would not charge them in the cold, 41 is not that far off from 32 and if you have the ability to warm them up I would as you would charge better.
The switch thing on the SFK seems nice, but its going to be draining the batteries keeping them around 70. I suppose if you have solar access then whatever you loose you get back. Interesting concept.
Battle born does something similar with there batteries with a wire:
