ok, I was just reviewing using a Tesla pack yesterday.
You need a controller that will do the following:
- Handle the maximum voltage of your panels - that'll be when they are coldest.
- Handle the maximum amperage of your panels
- Has adjustable charge setting that support lithium batteries
- Supports whatever pack voltage you choose - aka a single tesla module is essentially a 24v pack.
For a tesla module, you need a BMS that'll take care of:
- temperature protection - stop charging when too cold (or hot)
- voltage protection - stop over and under charging
- cell level protection - keeps cells balanced (same charge)
The Mortons on the move youtube channel has some good ideas on doing this:
An updated and refined design schematic of a DIY install of a Tesla battery module into an RV solar electrical system.
www.mortonsonthemove.com
- and I have to commend him on his work. That said, he doesn't (as far as I've seen in his vids) have active cell level protection. He's monitoring it now and then and then balancing if needed. (I would personally run an active BMS on that pack.)
Now, that said, you can get the BMS functions above from some other sources like the Morton build did - such as a battery monitor, etc.
Now to give you some actual answers:
Go put your solar panel info into the victron mppt calculator:
MPPT Calculator - Victron Energy
www.victronenergy.com
Now play with the voltage options - 12v vs 24v and I'd play with parallel vs serial for the two panels.
Bascially at 12v you need a heftier controller, at 24v you can actually downsize the controller a bit.
Many other controllers will support lithium charging, I just happened to chose victron for mine so I'm referencing their stuff.
