apctjb
- Jun 16, 2020
- 471
A 48V-560AH LiFePO4 battery bank I built about 2 years ago suddenly has a low cell. Nothing physical apparent, connections all tight including the BMS voltage sense wires. System has worked flawlessly up until recently when it went offline because the BMS disconnected because of a low cell.
Curious to hear from others what the problem could be? Note that the bank is comprised of 2-280AH cells in parallel , 16 series. I am thinking of temporarily bypassing the BMS so I can charge up the bank and see what happens. Bad idea??
Photos below...
Photos below...
