AndrewG
Having battery issues after snow covered panels.
System Specs: Off-grid
5000es Growatt Inverter/Controller
14 panels- 48v 365w 9.8 amp wired- 7x2 @ 19+amp- 3-eg4 batteries 100amp 48v 5Kw
2 rack & one LL - this is the one the BMS connects to the inverter.
Problem- Snow covered panels yesterday & drew system down to approximately 30% SOC. Lots of cloud cover today so low charging for 4 hrs. SOC climbed to 36% so I charged the system with a generator to bring batteries back up. Ran generator for 2+ hrs & brought SOC up to 46%.
After about an hour of just battery house usage, no gen, The system shut off entirely. Checked the LL battery for info and battery amperage read 0.4amps. What could be causing this? Batteries are in parallel I don’t understand the BMS indicating such a low reading.
Called SS earlier today because of a battery charging issue and they suggested some inverter setting changes, but it turned out the charging problem was bc the panels were totally covered in snow. At that time the Inverter showed 0.3amps/230v from panels covered in snow. Brushed off panels and got batteries up to the 46% SOC with PV & Gen mentioned earlier. Now, no power.
What should I be looking at now? Should I just try to top off the batteries with the generator in the morning? Gen spec is 9800w unit with a 240/50amp wired connection to inverter AC terminal.
Thank you in advance for any help.
Andrew
Andrew
