You will have to experiment a lot to determine the most appropriate settings for your setup. To date I have saved 10 configurations implying 10 complete charge and discharge cycles. It is a laborious task -- like watching paint dry.
Try the following settings :
Cycle capacity : 150.000 Ah ; Single full voltage: 3.5v ; Single cutoff voltage: 2,85v ; 80% cap: 3.300v ; 60% cap: 3.270v ; 40% cap: 3.263v and
20% cap: 3.221v and Discharge Over current: -150amps . Make sure that your cabling / fuses are rated for this higher current. Remember that inverters draw quite a large inrush current and the previous settings may have caused the BMS to trip.
You can always go back to previous settings and experiment further.
