Johno25
My DIY 8.4 kw grid tied solar array with Enphase M215 and M250 micro inverters are back feeding my home via a 40 amp breaker in my garage sub panel. I have ordered the EG4 18k inverter and the EG4 Power Pro battery to use for grid down-back up. I'm wiring the system for Whole House backup. My question is what happens if I leave the breaker from the garage in my main panel alone? I understand the EG4 passes thru the AC when the grid is up but, when the grid is down, will it be able to power my home and charge the battery? I understand that the micro inverters will not shutdown since they are not wired to the GEN port. I will shutdown the solar manually if the load is satisfied during an outage. I can also load dump to our two electric vehicles. Second question, can I terminate the garage sub panel feeders to the GEN port without separating the solar AC feed from this circuit? If yes, when the inverter frequency shifts will this harm any equipment in the garage (Wifi router, LED lights, garage door openers mainly)? Thank you for any feed back. I'm new to this forum but have been watching Will's Youtube channel for years.
![IMG_6454.JPG IMG_6454.JPG](https://diysolarforum.com/data/attachments/167/167196-1e63f30f07942030c5c2c4af5403cc8d.jpg)
