johnim
After a while now evaluating how much energy I can get out of a single EG4 48v 100amp battery I've come to the conclusion that it's not enough especially with 2 minisplits. So I'm adding 2 more server rack batteries for a total of 15kw potential. Whenever they're back in stock I'll get another 3kw inverter. For now I'm focusing on hooking up 3 batteries vs just the one. I know I have to balance them out so there's that but in one of Will's video he's using 2/0 wire for inverter supply and 4/0 wire for the battery hook up (the one where he uses 6 batteries and two 6.5kw inverters).
If I only have 3 batteries do I need that big a gauge wire? With the one and one set up I have 4 gauge inverter and 6 gauge battery cable that came with the products. the wire gauge current chart I'm looking at only goes up to 200 amps. Is there a good online resource for bigger gauges.
Also, another thing I don't understand. With Will's system he uses 200amp T fuses for each inverter and battery cables are going through a 300 amp busbar. For so many amps are those hefty enough? In my Signature Solar manual they recommend using 600 amp bus bars.
