magicmantx
I am installing the following components in building a new system using all Renogy components. I will have 12x 100 watt panels going to a 100a Renogy controller. 2- 200ah Renogy batteries. I will install a Renogy 3000watt inverter. Now here is my question on wiring sizes . If I go by the blue sea chart I would need 2/0 gauge wire from the inverter to the batteries but since the bigger draw I will have at one time will be a 13500 but ac for short periods of time , a 1500watt heater and a 7.0 cf refrigerator that draws 1.2 amps. so my max amp draw at any one time(I'd turn ac off to run microwave etc) would be under 30 amps. The AC will be connected in the breaker box with 12 gauge wire on a 20 amp circuit( spec by advent) . So all that said do I really need to spend the extra money to go with 2/0 wire to meet the maximum requirement of the inverter or go with 4 gauge which I have plenty of to do this project. What do ya'll think?
