My gut feel is you'd need 1000W of solar most times of the year. Far more if you get a few overcast days.
To get an idea of the potential from PV set up - I plugged in 0.618kW into PV Watts Calculator using Albuquerque NM (for example) 35 degree tilt, pointing due south.
The monthly range is 81kWh Dec to 103kWh April per month (Daily average: 2.64kW/day to 3.38kW/day)
PV watts is just an estimate, and some report that PV watts overestimates actual conditions, so I suspect you will fall short of the target 3.6kWh per day using the panels you noted.
If you can fit in one or two more may be more realistic.
For storage, since you don't likely have a lot of cloudy or rainny weather in NM, two days ESS (7.2 kWh) may be enough. ie about three times what you currently have in AGM batteries. Maybe you don't need two full days of ESS, though.
I went ahead and purchased three more 200W Renogy solar panels (are super cheap on Amazon now), so that brings the total to 2X at 215W and 4 at 200W. It's a 36' trailer so I'll have plenty of room for all of them.
My new question now becomes what would be the preferred layout. I ran the numbers for the following layouts (series/parallel):
I'm using the / to separate the voltage and amps of each panel, not dividing.
Layout 1 - 2 panels (series) with 3 groups (parallel)
Group1 - P1 - 12V/9.85 amp and P2- 12V/9.85 amp = 24V/9.85 amp and produce (21.8V+21.8V)*9.85amp = 429W
Group 2 - P3 - 12V/10.42 amp and P4 -12V/10.42 amp = 24V/10.42 amp and produce (19.2V+19.2V)*10.42amp = 400W
Group 3 - P5 - 12V/10.42 amp and P6 -12V/10.42 amp = 24V/10.42 amp and produce (19.2V+19.2V)*10.42amp = 400W
Total layout 1- 24V/30.46 amp - Need 8 gauge wire
Layout 2- 3 panels (series) with 2 groups (parallel)
Group1 - P1 - 12V/9.85 amp, P2- 12V/9.85 amp, and P3 - 12V/10.42 amp = 36V/9.85 amp and produce (21.8V+21.8V+19.2V)*9.85amp = 618W
Group2 - P4 -12V/10.42 amp, P5 - 12V/10.42 amp, and P6 -12V/10.42 amp = 36V/10.42 amp and produce (19.2V+19.2V+19.2V)*10.42amp = 600W
Total layout 2 - 36V/20.04 amp - Need 10 gauge wire
Layout 3- 4 panels (series) and 2 panels (series) with 2 groups (parallel)
Group1 - P1 - 12V/9.85 amp, P2- 12V/9.85 amp = 24V/9.85 amp and produce (21.8V+21.8V)*9.85amp = 429W
Group2 - P3 - 12V/10.42 amp =P4 -12V/10.42 amp, P5 - 12V/10.42 amp, and P6 -12V/10.42 amp = 48V/10.42 amp and produce (21.8V+21.8V+21.8V+21.8V)*10.42amp = 908W
Total layout 3 - 24V/20.04 amp - Need 10 gauge wire
Which layout would work best? Also, if you have another layout option please let me know.
Brenda
