ThrottleAbuse
- Aug 18, 2022
- 22
Hello, I am currently in the process of planning and upgrading my RV power system.
I am replacing my 4 worthless 6v 230Ah batteries with 2 Epoch 300Ah V2 lithiums. To do so I need to add a DC to DC charger and I want to be able to charge the lithiums as quickly as possible when driving my RV or running my generator.
I also plan on adding some additional solar which I would like some help picking the specs and components. I have purchased a Renogy IP67 50 DC to DC MPPT charger. I will be using the 50A Renogy as the controller for it so that unit will handle DC to DC and the added solar. Right now I was thinking three 200W 24V panels and one 100W 24V panel all wired parallel. I had seen some on Richsolar that would work but now I cant find the 100W 24V panels. I dont have any preference here I just want to maximize the controllers capacity. The controller is rated for 720W so this should max out the controller. I have lost of room on the roof. 6 or 7 panels will easily fit. Renogy recommends a 60A and 70A fuse on the output and input sides.
I also plan on adding a Recpro 125A AC to DC charger to boost charging capacity while on shore power or while running the generator. I will wire this to an open breaker on the current 120V system that only runs on shore or generator power. I am not particularly attached to the Recpro but this seems like a pretty basic use case so it doesnt seem like I need something expensive. I believe I will be able to mount it close enough to run 4awg wire. I may need to increase that to 2awg. Is a ANL 175A fuse safe here?
Here is a drawing of what I have planned. The Jaboni solar system is already installed and I am not 100% sure on how its connected but by knowing the specs I think all three 175W panels are wired in parallel. I also already have a Magnum 3000W inverter thats already installed. I will be disabling the auto merge and leaving a manual option to join house and chassis batteries.
For the battery install I see people recommending MBRF fuses. Do I just need a 600Ah fuse on the bus bar side since each batteries BMS is rated for 300A max draw? Do I need any other fuses on the battery part of this upgrade? 4/0 awg wire should be ok here between batteries and to the bus bars. Distances will be short.
Any advice on any part of this upgrade is much appreciated.
