12v is not a common size , but they are available
2200W 12V Solar Hybrid Inverter AC230V 80A Off-grid Max PV 2KW + AC Charger | eBay
(Be careful not to install it near the bedroom, the fan will make a sound when the inverter is running.Avoid affecting your rest (expect 50-70 db)). Nominal Input Frequency: 50/60Hz; Output Power: 1800W, surge Capacity: 3600W.www.ebay.co.uk
EDECOA Hybrid Inverters 12V 1600W 240V Off Grid Pure sine MPPT 80A 55-430VDC LCD | eBay
EDECOA Solar hybrid Inverter. Pure Sine Wave 12V 1600W MPPT 80A. 1x Hybrid Inverter 12V 1600W. Pure sine wave inverter (THD <3%). OFF grid: the inverter does not feed power into the grid. With the simple, intuitive LCD screen interface, you can easily change all system settings, including input...www.ebay.co.uk
PowMr 2000W Off Grid Solar Hybrid Inverter Charger Support 12V battery MPPT 80A | eBay
PowMr 1600W solar inverter 12 V DC to 220 V/230 V AC work with 12V lead-acid and lithium batteries. When you encounter a problem during use, the corresponding fault code will be displayed, which can help you solve the problem easily.In addition, this inverter has LED indicators, so you can see...www.ebay.com
Only a specific version of it, the MK if I recall, which was announced but I've never seen actually for sale anywhere.You can parallel the 12v MPP models.
Not exactly what you were looking for, but it will work.
Lots and lots of 2kw+ 12v inverters available on the marketIt would be silly to make it.
The MASSIVE amperage 12V requires at over 1500W makes an all in one very unreliable.
Think about it.
2000W of 12V conversion output assuming 90% efficiency is 185A... thats bigger than 4/0 copper, and a LOT of heat if undersized.
Solder joints would bake, and fetts would fail...
It is of course possible, but it would be an unwise decision.
Watts247 sold plenty of themOnly a specific version of it, the MK if I recall, which was announced but I've never seen actually for sale anywhere.
I said OVER 1500W is silly.So a 3000w on 24v is OK, and 12000w on 48v is fine but a 1500w on 12v would be silly?
And 2000w 12v inverters are OK since it's not an AIO?
Oh yeah, i have a 5kW 12V inverter.Lots and lots of 2kw+ 12v inverters available on the market
I do think you're right though , and it's not particularly logical to run say 200a+ @12v , when it could be done 100a@24v
But I guess there are lots of situations where it might be needed, especially where there is an existing 12v system like campers caravans RVs etc.
The last I looked, No longer even listed on his website anymore...Watts247 sold plenty of them
Idk where you're looking:The last I looked, No longer even listed on his website anymore...
I became a huge fan of that inverter that day ? I can't believe it pulled that off.@Will Prowse just had his Victron 12v Multiplus running a car lift in his latest video. Pretty impressive for a 12v inverter.
Well, how about that... I just looked a few times at his site last month and it wasn't listed anywhere...
Doing a quick Google search, it does seem that not many other places are selling it anymore. I wonder if they're being discontinued? Or perhaps replaced with a better modelWell, how about that... I just looked a few times at his site last month and it wasn't listed anywhere...
Dan what do you mean by Parallel?You can parallel the 12v MPP models.
I think they have communication. It will stay if you can do parallel connection with the output in the manualDan what do you mean by Parallel?
Someone might think you can join the two AC outputs. That would create a massive bang or worst.
Unless the Inverters have some form of syncing cable the outputs will be out of sync and blow up both inverters.
It's actually a very common feature for most MPP invertersDan what do you mean by Parallel?
