This is the problem.
Some alternator not and some do have it
So a dc to dc is not make to protect your battery
Its thare to save your alternator from overheating.
From one point this video is great, from other it is a false positive.
The devices on the video were coupled 1:1, but in reality there is a bigger ratio on the pulleys, so 1000rpm on the engine is about 2500rpm on the alternator.
I am in the process of creating a charge system to lifepo4 battery in my van, so my setup will have:
1. DC-DC boost converter (3 units at 30A), this unit has a ConstantCurrent and low voltage protection, it is 1800W at 40A input booster from Aliexpress.
2. rectifier diode per booster unit to prevent back-feed
3. an arduino for temperature and voltage control to automatically switch on/off booster units.
4. relay to enable unit
and after watching this video I need to add temp sensor on the alternator
just to prevent "magic smoke" from it.
My alternator is capable of 150A, so my idea was to draw max 90A, but now it need to be adjusted to the temperature levels.
below a picture of my test setup, that is just laid on the inverter inside the van, but it works and charges with 30A only when the engine is running, but when the ignition is on and engine off, the charge is about 5A (at the moment there is no planed external voltage control Arduino)
