This circuit can serve both as MP-park two stages charge controller or as power diverter, if you want to use surplus energy to heat water or living spaces.
It is based on tl494/tl598 pwm controller, two voltage control loops are realized , one for input voltage, the converter starts above the preset voltage, to keep MPP point as charger use, or to keep the final charge voltage as diverter use, and an output voltage limiter loop, to provide final charge voltage as charger, or for safety redondance if is used with a diverter.
It can built in wide variety of voltage range from 10v to 1000v, reference schematics are for 100-300v range.
