Anenji ANJ-6200W-48V
rer445435
Prague
Hi everyone
Attaching User's manual for the subj.
In case you need it
  • ANJ_6200W_48V.pdf
Now I set it up just like inverter. No PVs
Going to connect JK BMS to it.
Due to inverter has only RS485 (Modbus) battery interface, going to implement the middlware HW like JK UART <-> RS485 (Modbus Pylontech)
Hi everyone
In case you need it
Hello, I have the same Inverter ANJ-6200W-48V-wifi. The Hybrid Solar/Charger inverter is connected with 5kW 48V LifePo4 Battery.
Can someone show me how to set it to work in Battery mode. I need output power from the Battery and PV. My inverter is currently working in Line mode, which does not respond to me.
Thank you
