I have a 48v 105 ah 16 cells pack that I got for free to mess with. there is some corrosion on a couple of bus bars from a leaky case. (this was installed in a golf cart) The cells are in need of top balancing but the bus bars are welded .
Is there any way to safely grind off/remove the bus bars? I'm planning on a new bms, I think the original is shot, and I may make 2 24 volt batteries out of this for my needs.
Thanks
Thanks
