jmacdonald077
Here is an idea. Assume a Sol-Ark 12K or 15K is already in place with xx kW PV array running. No generator connected to the "GEN" input.
Since the GEN input allows for AC coupling of additional power sources (most typically an existing PV array w/inverter), could this input be used to feed in a wind turbine, which was outputting 120VAC through its own DC-AC inverter?
