Are there any hybrid inverters that are designed to use LiFeP04 ion batteries? TYPO, I meant iron.
So far all I have found inverters that support Lithium ion, Lead acid and Agm. Very short sighted if you ask me.
Ok, so you have LiFeP04 batteries, hook them up to the inverter, plug in your BMS communication and run the batteries on a lead acid setting. Does the inverter really communicate with the BMS using a lead acid setting? If so any down side to this?
Or do the majority of people use open loop?
