Hi All,
Fantastic resource here - lots of info to be absorbed!
I live in Victoria and have a 5kw grid tied Goodwe inverter with approx 5.5kw of panels. I'd like to add 10-15kw of batteries to further reduce my consumption from the grid. I'd also like to have black out protection in the (very rare) scenario that the grid goes out.
I also want to make sure everything is 'above board' as I'm still going to be grid connected.
From my research, it seems I have the following options:
Batteries:
In Australia we have a CEC list of 'approved batteries'. It seems to me, that this 'approved list' is only showing which batteries can receive a state government rebate if they are installed.
It seems I can install any LifePo4 battery, to a grid tied system - it doesn't need to be on the CEC list. It's hard getting any good advice from installers, they all tend to default to Tesla powerwalls.
Replace current inverter with Hybrid inverter:
Seems the easiest option is to simply replace my current inverter with a hybrid inverter. I would need to make sure it would be compatible with the batteries I want to choose.
I would have backup during a grid failure (although seems most hybrids max out at 3kw draw from batteries) and also allow the option of panels still charging batteries even if there is a grid failure. This system will also be more efficient, as there is no DC > AC > DC conversion happening.
Keep current inverter and install Victron Multiplus 2
Another option is to AC Couple a Victron Multiplus 2 to my current system. This won't be as efficient when charging batteries due to going from DC > AC > DC.
It does allow me the option of adding additional solar panels down the line by purchasing a MPPT to also charge the batteries
One thing I'm not 100% sure is what happens during a grid failure. I know batteries will be used (up to 5kw draw), but I'm unclear if the panels will still be able to charge the batteries, as I assume the Goodwe would switch off and thus no power
Looking forward to any suggestions, especially from fellow Aussies who have gone down this route!
Batteries:
