Nathan Barnard
- Sep 14, 2021
- 22
Looking for advise on matching and/or removing weaker batteries to maintain this battery pack.
I've been using it as is for the last two years. I has been performing well with daily discharges of 500-600ah @24v, it has stayed balanced up until recently. The lower side is dropping off much quicker than upper side. I regularly pull 250amps from it (for electric oven or clothes dryer) and charge around 100amps with solar.
Yesterday I charged both sides up to 14.2v and held them there overnight, then this morning I disassembled and tested each battery on a digital CCA load tester, marking down the cranking amps and internal resistance. I put it in a spreadsheet to try to figure out which batteries I should switch to balance average resistance and CA on pack (so they would discharge and recharge equally). I'm not sure if this is the best way to balance a pack for longevity, or even what a high resistance, low state of health battery does to a pack. Perhaps I should be eliminating those batteries altogether?
Specs:
26x Eaton Powerware 12v 390W VRLA AGM batteries, forming two strings in series of 13 batteries for 24v. (Appx 100ah 12v ea)
Specs:
Ohms (Left 13 batteries) | CA | Ohms (Right 13 batteries) | CA |
12.4 | 300 | 13.1 | 280 |
6.3 | 585 | 10.2 | 365 |
9.5 | 395 | 6.8 | 550 |
5.5 | 675 | 11.7 | 315 |
12.1 | 305 | 11.1 | 335 |
11.6 | 320 | 6.7 | 560 |
8.2 | 455 | 11.3 | 330 |
8.3 | 450 | 5.8 | 645 |
7 | 530 | 4.9 | 750 |
7.4 | 505 | 11 | 340 |
10.9 | 340 | 11.1 | 335 |
13.7 | 270 | 6.7 | 555 |
5.1 | 735 | 7.6 | 490 |
average Ohms 9.1 | 5865 | average Ohms 9.1 | 5850 |
TOTAL CA | TOTAL CA | ||
Lower 12v | Upper 12v |
